Activity Forums DVD Authoring Removing HVDVD_TS Folder in builds location
  • Removing HVDVD_TS Folder in builds location
    Posted by Karina Louw on November 25, 2012 at 5:11 pm
    Hi there,
    I recently reinstalled FCS3 – and by accident I must have selected HD video standard when i launched DVD Studio pro for the first time. I realized my mistake when I burned a dvd and it would play in DVD player or my computer (although it worked fine in simulator). So in the preferences window I changed it back to SD dvd – but when i pressed the burn button again (after re-authoring dvd with SD setting) the following message appeared:
    “The Build Location folder contains a HVDVD_TS folder(HD DVD content). You must remove the HVDVD_TS folder from the Build Location in order to proceed with Build/Format of a Standard DVD project”
    Sorry if this is a stupid question but – how do I do this? Any help will be greatly appreciated.
    K
    Karl Bergvall replied 12 years, 7 months ago 3 Members · 2 Replies
  • Bill Stephan
    November 26, 2012 at 5:39 pm
    Just navigate to the location set in DVDSP as the build folder, then take the HDDVD_TS folder you find there and drag it to the trash (or recycle bin). Then you will be good to go. DVDSP will put a new VIDEO_TS folder in its place.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Karl Bergvall
    October 7, 2013 at 12:07 pm
    how do you find the location of the build folder ?
