Activity Forums Adobe After Effects Removing HD pulldown.
  • Removing HD pulldown.
    Posted by Andrew Wardlaw on May 11, 2006 at 10:57 pm
    I need to add some effects to footage that was shot on the Varicam. It was shot at 24p, digitized at 720p (59.94). That’s the media I have.
    If this were NTSC footage, I’d remove the pulldown in “interperet footage”, do my effects in a 24fps workspace, and then add a pulldown upon rendering.
    But since it’s 720p, there are no fields to remove. And if I get the footage into a correct 24fps workspace, how do I render it back to 59.94p?
    Any thoughts? I’m running AE 6.5.
    Andy
    Steve Roberts replied 20 years, 4 months ago 2 Members · 1 Reply
  • Steve Roberts
    May 12, 2006 at 4:11 pm
    If you have FCP, you need to convert the 59.94 footage to 23.98 using the frame rate convertor. Go to this Ken Stone article and go down a few paragraphs to the links in the article.
    If you don’t have FCP, you’ll need something else to convert the files. Check the Panasonic Varicam COW forum for more.
