Activity › Forums › Maxon Cinema 4D › Removing hair from object
  • Removing hair from object
    Posted by Shane Robertson on March 26, 2013 at 11:57 pm
    I think im missing something simple. I have a plane with hair on it. I want to delete hair from a certain part. Cut tool will leave stubble and scale does nothing to it. Is there a way to delete the hair completely?
    Thanks for the help!
    Shane Robertson replied 13 years, 6 months ago 2 Members · 2 Replies
  • Brian Jones
    March 27, 2013 at 12:07 am
    if it’s an editable plane the easiest way is to make a poly selection of where you want to keep the hair, save that selection then put the selection into the Hair object Guide tab Link slot. If you need to keep the plane as a primitive then use the Length parameter in the Hair material and use a texture in there that will give you what you need.
  • Shane Robertson
    March 27, 2013 at 12:20 am
    Thats exactly what I needed, thank you so much!
