Activity › Forums › Apple Final Cut Pro Legacy › Removing effects on whole track
  • Removing effects on whole track
    Posted by Michael Tysh on December 10, 2007 at 5:12 pm
    Hello fellow editors,
    I was wondering if it was possible to select a track and remove the same effect from every clip on the track.
    example: I have a color corrector on every clip of a certain angle that rests on the same track in my timeline. I’d like to remove the color corrector from each clip on the track without having to double click on each separate clip and delete the effect.
    I didn’t do an extensive search in the manual, but searched for things such as “removing/deleting effects”.
    Any help or information would be appreciated
    -Mike
    Michael Tysh replied 18 years, 9 months ago 2 Members · 2 Replies
  • Tom Wolsky
    December 10, 2007 at 5:15 pm
    Do a sequence search for the clips and use the Find All function. That will select all the clips with the same name. Then use Edit>Remove Attributes. Click Filters and OK.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
    Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
  • Michael Tysh
    December 10, 2007 at 8:15 pm
    Thank you, very helpful!
