Activity Forums Adobe After Effects Removing Edge Flicker From Chroma Keyed Background
  • Removing Edge Flicker From Chroma Keyed Background
    Posted by Jeff Nghiem on July 25, 2006 at 4:17 am
    Hello Creative Cow Community,
    I have recently tried chroma keying in After Effects 6.5, removing a background that is not a solid color (i.e., a living room with many different colors tied in) and have come very close to successfully creating a crop without the hassle of rotoscoping the talent/foreground. The only problem is “edge flicker”. Does anyone have any suggestions on how to suppress the flickering? I have applied a matte choker with an edge blur and edge feather, denoisers or a combination of these filters to no avail. Any suggestions would be greatly appreciated. Thanks in advance for your time.
    Sincerely,
    fatpoh
    Jeff Nghiem replied 19 years, 12 months ago 2 Members · 2 Replies
  • Barend Onneweer
    July 25, 2006 at 2:13 pm
    You could try a pass of Remove Grain before applying the key. Usually the jittering edges are a result of amplified noise or grain in the image.
    If you’re worried about losing image detail in the denoised foreground, you could actually use the result from the key as a track matte to the original footage. That way you pull the matte from the denoised footage, without losing any foreground detail.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Jeff Nghiem
    July 25, 2006 at 11:42 pm
    Thanks Bar3nd for the tip. I tried out your suggestion and the result did decrease the amount of flickering. Are there any other suggestions that I could apply to further decrease the amount of flickering on the chroma key? Thanks for your quick and concise respose. It was a great help.
    Sincerely,
    fatpoh
