Activity › Forums › Apple Final Cut Pro Legacy › removing echo – noise gate? what does it all mean.
  • removing echo – noise gate? what does it all mean.
    Posted by Anne-marie Steenbergen on February 13, 2009 at 3:50 pm
    We have a small studio set up in a living-room with a reasonable high sealing. Green screen, professional lights and a desk are also in the room. The building is a monument so there are wooden panels attached to the walls.
    A news presenter reads the news.
    Now we have a problem there is a hollow echo in the sound.
    I’ve tried Expander/Noise Gate but it gets worse.
    The problem is also that I don’t know what I’m doing as I don’t understand what it all means and does.
    Can someone explain it?
    I also tried combining it with AUParametricEQ and AUGraphicEQ but that doesn’t help.
    How do I get rid of the echo?
    I have also soundtrack pro, but I don’t know how to use it.
    Thanks in advance.
    Anne-Marie
    (English isn’t my first language)
    William Hughey replied 16 years, 7 months ago 5 Members · 4 Replies
  • Dennis Leppell
    February 13, 2009 at 4:01 pm
    Instead of fixing it in post, in the future you should fix the problem at the source.
    Sound waves are like rubber balls. They like to bounce around. The wooden panels on your walls is giving them a really nice service to bounce off, and then picked up by your microphones. The more uninterrupted the surfaces that are available for the soundwaves to reflect off, the more pronounced the effect. An empty rectangular room with hard floor will echo horribly, but if you fill it with carpet, furniture, drapes, etc, the echo dies.
    To fix your issue, hanging foam padding, drapes, or even sheets or blankets to absorb these stray soundwaves will have great results on your future sound recordings.
  • Mike Johnson
    February 13, 2009 at 6:49 pm
    I had the same problem on a project a couple of months ago. The camera op didn’t use headphones to check the audio and there was a bad echo. Come to find out he didn’t have the audio input set right on the camera and it was taking the signal from the onboard mic rather than the lav. After fiddling with the audio for about a day in both FCP and STP we finally got it fixed. We reshot the interview. If the echo is subtle, you can try to cover it up with a music bed. Otherwise there’s not much that can be done.
    Mike Johnson
    Final Cut Pro Editor
    Drury Outdoors
    http://www.druryoutdoors.com
    View Mike Johnson's profile on LinkedIn
  • John Fishback
    February 13, 2009 at 8:59 pm
    If it really is echo, you can’t remove it. However, it sounds like some phase cancellation may be happening. That’s where sound from talent reaches the mic at a slightly different time than a wall reflection and that can create that hollow sound. Frequencies from 150 to 400 Hz are the range to play around with. Try cutting and boosting in this region and see what happens. Use a parametric eq.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • William Hughey
    February 16, 2010 at 3:38 am
    If you can not hang acustic dampning material (egg crate, sheets ,carpet) on the walls you might want to try sampling the talent, and feeding a small ammount of audio back into the room 180 degrees out of phase. This will cancell some of the echo or some of the audio frequencies. This will depend on the room size and placement of the monitor speaker. Audio delay is also a nice thing to have on hand when “trying” to cancel echo or acoustic echo in a room electronically instead of mechanically.
    Sample the audio either from the mic or second mic, delay the audio just a bit (a few ms, 65 ms is good by routing the mic through an adjustable audio delay board) then to a amp and monitor speaker (placement in the room will have the greatest effect) invert the phase of the sampled audio (switch the polarity of the speaker around not great but effective on a budget) adjust the delay, audio level, and placement of speaker for best effect.
    This is not easy it is not an exact science you can try it with out spending thousands of dollars on computer programs and equipment. The best way to stop acoustic echo in a room is with sound absorbing material or sound dampening material, Foam packing material that resembles a egg container with peeks and valleys will work as well as the expensive stuff made for the studio. If you cannot hang something on the walls try the phase echo cancellation experiment.
