Activity Forums DaVinci Resolve Removing Dead Pixels
  • Removing Dead Pixels
    Posted by Ben Edwards on May 1, 2013 at 8:30 pm
    Hi, thanks for everybody’s help so far.
    One on the cameras the footage was shot on has dead pixels (which show up as white spots). Its a dance pice in a theatre so the background it black. Was wondering if it was possible to set a qualifier on white pixels so I can turn them down. Tried but no luck. Cant use hit them with picker, if I zoom in enough to get then they are off screen (shame you cant scroll around window when it is zoomed in.
    Any ideas?
    Ben
    Ben Edwards – Freelance Picture Editor
    https://www.funkytwig.com
    i5 550, Windows 7 / Mac Lion, Nvida 550 Ti, 8GB Mem
    Eli Bierwag replied 13 years, 2 months ago 7 Members · 7 Replies
  • 7 Replies
  • Rohit Gupta
    May 1, 2013 at 10:52 pm
    You can use the middle mouse press and drag to scroll around the image.
  • Ben Scott
    May 2, 2013 at 9:45 am
    have a look at boris BCC effects they have a pixelfixer
  • Neil Patience
    May 3, 2013 at 12:44 am
    Hi Ben
    Digital Heaven have a pixel fixing plug-in for FCP4-7 and FCPX called Reincarnation. If you use those editing platforms worth a look. Its $59.00US
    https://www.digital-heaven.co.uk/plugins
    best wishes
    Neil
    http://www.patience.tv
    8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
    i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
  • Joseph Owens
    May 3, 2013 at 3:17 pm
    [Ben Edwards] “Was wondering if it was possible to set a qualifier on white pixels so I can turn them down.”
    Stuck pixels don’t move around (but moving objects in the picture content obviously complicates the correction) so what I normally do is crate a teensy weensy power window and set a blur so that the pixel is naturally migrating towards whatever the adjacent pixel values are.
    This approach breaks down whenever an edge crosses the qualifier, so it requires a keyframe/tweak. So the technique either works a treat or (depending on picture activity) is more trouble than its worth.
    However, it doesn’t require any plugins or roundtripping pass-back and forth.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Ben Edwards
    May 3, 2013 at 6:41 pm
    Thanks, will give it a try, nice solution. Pitty there is more than ong;).
  • Alan Gordon
    May 15, 2013 at 10:21 pm
    THIS is changing my life forever! Wish I knew about this years ago!
    -Alan
  • Eli Bierwag
    July 11, 2013 at 6:17 pm
    I use your power window technique as well, but I usually do a noise reduction rather than a blur. Blur is less resource intensive (won’t slow down the machine) but NR will be less visible.
