Activity › Forums › Apple Final Cut Pro Legacy › Removing De-interlace
Posted by David Mercer on July 22, 2006 at 12:28 amHi Guys
Can I remove a video filter (de-interlace) from a selection of clips in your browser?
Many Thanks
D
David Mercer
David Mercer replied 20 years, 2 months ago 2 Members · 2 Replies -
Rennie Klymyk
July 22, 2006 at 12:40 amJust click on the filters tab on the browser and uncheck that filter. If that is the only filter used on the said clips you can copy the clip in the time line, then highlight the other clips and paste attributes to the others. If you have other filters on any of them you will have to do them one by one in the canvas.
“everything is broken”
David Mercer
July 22, 2006 at 1:22 amArrrr ok.. that makes sense.
So there’s no direct way to remove a filter from a number of master clips in the browser. It would be nice if you could just highlight all the browser master clips, ctrl click, hit remove atributes then select filters etc.
Is there a way to quickly toggle all filters applied to clips in a sequence on or off?
D
David Mercer
