Activity Forums Apple Final Cut Pro Removing bouncing stuck pixel
  • Removing bouncing stuck pixel
    Posted by Daniel Horn on September 9, 2015 at 12:16 am
    New to FCPX, worked in 7 for a few years but I’d like to fix this in X if I can grasp it. I made a video and I’m very happy with it but I have a bright green pixel that’s stuck and I can’t figure out how to get it out. What’s making it more difficult is that I used stabilization and zoomed a bit on some of the shots so it’s effectively making the pixel bounce around and move positions. I was hoping to just isolate the color with a keyer, remove it and apply that to every clip but I just can’t figure it out. What could I do?
    Nick Meyers replied 10 years, 11 months ago 4 Members · 3 Replies
  • Noah Kadner
    September 9, 2015 at 6:09 am
    Can you post an example screenshot. That’s generally a fixable flaw though not a stock built in function (of any editor I’m aware of…).
    Noah
    FCPWORKS – FCPX Workflow
    Call Box Training
  • Mark Suszko
    September 9, 2015 at 3:01 pm
    May I suggest Digital Heaven which offers a dead pixel remover.
    I think to do this right, you really need to go back and treat the original footage, then re-import it into the finished project and re-do all the other things you did to it.
  • Nick Meyers
    September 10, 2015 at 1:59 pm
    you want to post this in the FC X techniques forum
    this is for FCP & and under.
    however, the simplest approach would be to fix the dead pixel BEFORE you do the stabilising.
    nick
