Activity Forums Adobe After Effects Removing black bars on TOP and BOTTOM
  • Removing black bars on TOP and BOTTOM
    Posted by Danny Paz on February 6, 2016 at 2:01 am
    Hey, so I’m working on a project where I rotate a clip and use motion tile on it as well. Though I have this issue that the black bars on top and bottom of the clip make it so I can’t see only the clip inside of the black bars. I also tried masking over it, but as I rotated to see the motion tile, I saw a huge gap until I saw the motion tile itself. Basically I also can’t see the motion tile because of the bars as well. I try cropping it, but the bars are still there. I just don’t know a way to actually remove or delete something of a clip. Please help
    Pavan Gulati replied 9 years, 3 months ago 5 Members · 5 Replies
  • Tero Ahlfors
    February 6, 2016 at 8:19 am
    You probably need to scale the clip up during the rotation so the edges aren’t visible when you rotate it.
  • Jon Simpson
    February 7, 2016 at 3:16 pm
    It is hard to understand what you are describing. Can you render it out and provide a link so we can see what you are talking about?
  • Pavan Gulati
    February 10, 2017 at 1:19 am
    Hi Danny,
    Did you ever get this resolved. You were experiencing the exact problem that I am having. I am getting the huge black gaps between the tiles with the video clips. When I try the same effect with images, I don’t have the problem.
  • Roei Tzoref
    February 10, 2017 at 4:03 pm
    1. scale the video a tiny bit until it’s covering all the frame completely
    2. precomp the footage -> move all attributes
    3. now use the motion tile effect
    you could also
    1. precomp the footage – leave all attributes
    2. activate the collapse switch
    3. now you can scale the layer a bit and the gap will go away
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Pavan Gulati
    May 26, 2017 at 4:30 pm
    @Roei… I never thanked you for your post. Thank you!!
