Activity › Forums › Apple Final Cut Pro Legacy › Removing black background from shot
  • Removing black background from shot
    Posted by Drew Richards on August 30, 2008 at 11:03 pm
    Hi there…new to FCP.
    I have a shot of Mick Jagger dancing in front of a solid black background which I’m trying to overlay on top of a shot of a toilet (don’t ask).
    I color corrected the Mick Jagger shot to make the background darker, then I go to “Modify>Composite Mode>Add.” I’ve also used “Modify>Composite Mode>Screen.” This removes the black, but it also makes Mick look transparent. So it looks like the ghost of Mick Jagger dancing inside a toilet, which isn’t quite what I’m after. I tried laying the same Mick shot on three different video tracks but it still looks somewhat ghost-like.
    Anyone have any ideas? Doesn’t have to look perfect…I’ll settle for decent. Thanks!
    Tom Brooks replied 18 years ago 4 Members · 4 Replies
  • Shane Ross
    August 30, 2008 at 11:51 pm
    This won’t work in the way you are trying, as Mick will ALSO have black on him, so you will always see through him. Unless you rotoscope a mask around Mick…frame by frame. I wouldn’t recommend FCP for this, I recommend Shake or After Effects.
    This is why people GREEN SCREEN footage, so they can key out GREEN. Keying out black won’t work because of shadows and stuff.
    Shane
  • Tom Brooks
    August 31, 2008 at 3:50 am
    Do you have After Effects? Your challenge is to make a decent matte in the black area around Mick. You might be able to use Keylight’s more extensive tools to get to “decent.” As a quick experiment you might try several layers of your color corrected Mick in Screen mode on top of each other. This should get you a thicker Mick.
  • Kevin Monahan
    September 1, 2008 at 5:14 pm
  • Tom Brooks
    September 1, 2008 at 10:22 pm
    I sometimes have wishful thinking for transfer modes. Screen mode would always leave transparent areas if the background is anything but black.
