Activity Forums Adobe After Effects Removing bald spot shine
  • Removing bald spot shine
    Posted by Alan Balch on February 7, 2014 at 5:47 pm
    Hi All,
    I’ve been searching on the COW for answer to this question but am coming up short.
    I’ve got a talking head interview with a shiny spot on top of his head and I need to knock it down.
    Tried using an adjustment layer, but I’m not as familiar with AE as I thought I was.
    Any thoughts?
    Alan Balch
    Videographer/Carle Foundation Hosptial
    alan.balch@carle.com
    Erik Lindahl replied 12 years, 6 months ago 2 Members · 6 Replies
  • Erik Lindahl
    February 11, 2014 at 7:25 am
    Also, with some masking as mentioned above I beilive the “Beauty Box” filter combats skin shine quite well / naturally. We’ve used it for numerous shots for so called “post makeup” where it works brilliantly (even on dogs! :)).
  • Alan Balch
    February 11, 2014 at 4:06 pm
    Dave,
    Thanks for your input. Here is a picture of what I’m working with.
    I tried using the curves effect and found that ‘plastic’ look you mentioned to be pretty bad.
    Alan Balch
  • Alan Balch
    February 11, 2014 at 4:09 pm
    [Erik Lindahl] “I beilive the “Beauty Box” filter combats skin shine quite well / naturally. We’ve used it for numerous shots for so called “post makeup” where it works brilliantly “
    Thanks, Erik.
    I’ll give that a try. I also want to try using a Track Matte in PPro to see if I can put a dim on just the bright spot. Ever had any luck with something like that?
    Alan Balch
  • Erik Lindahl
    February 11, 2014 at 4:29 pm
    This is just a few minutes work in AE but here goes:
    BEFORE
    AFTER
    In the above example I used Beauty Box on the image and created a matte to isolate the effect primarily on the highlights of his head. Maybe a little to aggressive but one would have to see how everything looks finally comped and with a grade on it to really appreciate the effect.
  • Erik Lindahl
    February 11, 2014 at 4:31 pm
    Hmm… tried to reply to this post but I think my answer is being moderated or some thing. We shall see if it appears soon.
  • Erik Lindahl
    February 11, 2014 at 4:35 pm
