Activity Forums Avid Media Composer Removing audio tracks from digitized footage without recapturing?
  • Removing audio tracks from digitized footage without recapturing?
    Posted by Bluewingoliver on September 25, 2006 at 9:14 pm
    Is there an easier way to do this without delinking, modifying, and redigitizing everything?
    For example, if the footage was captured with 4 audio tracks, and I only want 2.
    Thanks in advance.
    Bluewingoliver replied 19 years, 11 months ago 4 Members · 4 Replies
  • Sfavidguy
    September 25, 2006 at 9:37 pm
    Yes,
    Use the media tool to find your clips. Highligh and hit delete. when the dialog box appears, you can select the tracks you want to delete (only 3 & 4 ibn your case). The clip will still show that it has 4 tracks with a 3 & 4 offline.
    Evan Stewart
    Philo Television
    San Francisco
  • Michael Phillips
    September 25, 2006 at 11:59 pm
    And then you can always subclip the remaining clip to be V1A1A2 if you don’t want to deal with audio tracks 3 and 4 on the source clips.
    anything 24fps
  • Michael Hancock
    September 26, 2006 at 1:41 am
    I’m curious–why do you need to get rid of two tracks? Rather than go through the trouble of removing two, just leave them but don’t patch them in when you edit. Audio takes up very little space, and it hardly seems worth the effort to delete two tracks when you can, simply, ignore them. Again, just curious.
    Mike.
  • Bluewingoliver
    September 26, 2006 at 6:24 am
    I usually just ignore them as well, but they annoy me ever so slightly at times. Mainly, I was curious as to how to do it. 🙂
