Activity Forums Adobe Premiere Pro Removing Audio Hiss In Premiere
  • Removing Audio Hiss In Premiere
    Posted by Paolo Mastrangelo on July 11, 2014 at 2:58 am
    Hi all,
    Thanks for taking the time to read.
    I recently shot a short interview with a Canon t5i, and there is noticeable audio hiss. Removed with Premiere’s DeNoiser, but the hiss returns when I add transitions to cuts. I’ve tried fiddling with the transitions and DeNoiser levels to mitigate, but have been unsuccessful.
    Hoping someone reading has experienced this as well, and can provide a solution or point one.
    Looking forward to reading your feedback,
    Paolo
    Paolo Mastrangelo replied 12 years, 2 months ago 2 Members · 5 Replies
  • Dennis Radeke
    July 11, 2014 at 8:53 am
    Paolo,
    Assuming you have Audition, send the edit (or the clip’s audio) to Audition and have it remove the offending noise. There are a few tutorials on this, but here’s a couple to look at that may put you on the right path.
    Audition Noise Removal
  • Paolo Mastrangelo
    July 11, 2014 at 3:30 pm
    Thanks for your response Dennis. Turns out I do not have audition though. Do you have any other ideas?
  • Dennis Radeke
    July 13, 2014 at 11:28 am
    Download the trial and use it for free for 30 days. That’s the easiest solution.
  • Paolo Mastrangelo
    July 14, 2014 at 12:34 pm
    I was able to do this using the “DeNoiser” function. You can watch the clip (with Jason Momoa) here: https://www.facebook.com/photo.php?v=10152390572173884
    The hiss was originally so bad, I considered not using the video.
    Thanks for your feedback.
    Paolo
  • Paolo Mastrangelo
    July 14, 2014 at 12:35 pm
    Thanks Dennis, will look at that.
    In meantime, I was able to do reduce the hiss using the “DeNoiser” function. You can watch the clip (with Jason Momoa) here: https://www.facebook.com/photo.php?v=10152390572173884
    Paolo
