Activity › Forums › Apple Final Cut Pro Legacy › Removing Aperture info from FCP7 QT files
Posted by Robert Longwell on August 22, 2010 at 12:21 amLong story short, I have a \”client\” who\’s transcoding farm will incorrectly transcode any QT ProRes file created by FCP7 due to the aperture tags. They will only accept files created in FCP6 or FCP7 files that have been re-compressed in Compressor 3.5.2 which can strip the aperture. Quite honestly that\’s a massive amount of re-transcoding to remove some metadata and very time consuming.
Does anyone know of any tools that can strip the aperture info out of a QT file? Preferably something object C based so we can automate this via command line.
Robert Longwell
Robert Longwell replied 16 years ago 6 Members · 18 Replies -
Rafael Amador
August 22, 2010 at 2:10 amHi Robert,
Bouke Vahl has an application called QTChange that can batch modifie QT files properties.
I don’t see Aperture as an option, but you can talk with the developer (Vouke valh):
(https://www.videotoolshed.com/product/42/qtchange/2)You can have a look as well to those QTTools:
https://www.omino.com/sw/qt_tools/
Rafael -
Bouke Vahl
August 22, 2010 at 9:46 amQTchange can set the ‘current’ and ‘normal’ size.
In some cases that will do the trick just fine. (Aperture does the same but has another approach.)
Just test it, it’ll be a very fast process.Bouke
smart tools for video pros -
Robert Longwell
August 22, 2010 at 4:23 pmNo sorry QTchange didn’t remove the aperture. And QT tools doesn’t modify these either. Still searching…
Robert Longwell
Bouke Vahl
August 22, 2010 at 4:33 pmI know it can’t alter the aperture.
But that could not be needed. Chances are that with new display settings the other app. will see it in it’s native resolution.
(so that needs to be tested…)Otherwise, use FFmpeg with -vcodec copy etc….
Bouke
Robert Longwell
August 22, 2010 at 7:09 pmThis issue isn’t the display settings. The issue is the mere presence of the clap size 1888×1062, that’s what their transcoder sees.
I found that I can edit this value in dumpster in 2 locations. In this case I edited them to 1920×1080:
The catch is I need to automate this, we can’t do each one of these by hand.
Robert Longwell
Carsten Orlt
August 23, 2010 at 12:55 amJust tested dumbster because I didn’t know it and I do not have half the info in my ProRes files you have. And certainly no Aperture info.
Maybe you could describe how you create those QT ProRes files.
Alternatively have a look at CatDV. Might (or might not) be able to help 🙂
Cheers
Carsten
Robert Longwell
August 23, 2010 at 1:36 amIt is an export straight out of final cut 7. It’s just 10 seconds of bars and tone and a chapter marker track. Really no frills here.
Robert Longwell
Rafael Amador
August 23, 2010 at 2:04 amHi Robert,
Pictures comes out of FC with “Production Aperture”.
I don’t think you must chance Aperture dimensions , but flag the files as one of the tree Aperture options.
I guess you need to change just one value in the file, but really I don’t know where.
Rafael
PS: I’ve never used Dumpster before. Is very interesting. -
Carsten Orlt
August 23, 2010 at 2:22 amHmm. I opened (in dumbster) a QT ProRes file I captured from using FCP7.
Sorry I think this is beyond my knowledge. Hope somebody else can help.
Cheers
Carsten
Bouke Vahl
August 23, 2010 at 11:46 amwell, besides FFmpeg, why not Applescript QT?
Bouke
