Activity Forums Apple Final Cut Pro Removing all effects from a clip or multiple clips
  • Removing all effects from a clip or multiple clips
    Posted by Steve Connor on August 31, 2011 at 10:24 pm
    At the moment I am doing the following to remove ALL effects from a clip or group of clips
    I select a clip with NO filters or effects, “copy” and then select “paste effects” to the clips I want to remove the effects from, this does seem to work
    Am I missing a “remove effects” command somewhere or is this another feature request?
    “My Name is Steve and I’m an FCPX user”
    Andy Neil replied 14 years, 11 months ago 3 Members · 2 Replies
  • T. Payton
    August 31, 2011 at 11:18 pm
    Cool workaround.
    However, I just thought of a different way that is more flexible. Select the clips and then in the inspector and then make any adjustments needed: turn off the effects/reset the color board, delete the filters, etc. and it will turn them off/delete for all the selected clips.
    As a bonus this techniques also works to add filters to multiple clips. Just select them, and double click on a filter to add the effect to all selected clips. Works for audio filters too! The only thing it doesn’t work on is the color board. ;(
    While you are at it you can make pseudo “groups” of clips by changing the name in the inspector (a little wierd yes, but it doesn’t change the file name just the clip name in the timeline) and using the timeline index to select all the clips in your “group” at once. So you could create a group for SFX for example and then modify the audio levels. Or perhaps a color grading group where you add filters for that group.
    Maybe there are other ways to pull this off?
    T. Payton
    OneCreative, Albuquerque
  • Andy Neil
    September 2, 2011 at 4:18 pm
    I’ve also taken to using adjustment layers to apply a single effect over multiple clips as opposed to copy/pasting effects because copy/paste in FCPX is so limited. This way, I only have to delete the adjustment layer to remove the effects. Kinda an Avid way of working.
    Andy
    https://www.timesavertutorials.com
