Activity › Forums › Apple Final Cut Pro › Removing a project FAIL…
Posted by David Stembridge on August 6, 2015 at 7:49 pmI created a couple events to add projects, mainly for testing. I shut down FCPx (10.2.1) and deleted the project folders from my movies/project-LIBRARY folder. When I opened FCPx again, the projects are still in my Library in FCPx… just no events and no option to delete.
What do I need to do to get rid of these guys?
-another fine day at
GreenPeas Productions
http://www.greenpeas.us
<“)))))><Bill Davis replied 11 years, 1 month ago 6 Members · 5 Replies -
Jeff Kirkland
August 6, 2015 at 9:21 pmJust trying to get my head around what you did….
You delete libraries in the Finder. You delete projects and events from inside FCPX. You’re saying you deleted projects and/or events in the Finder?
If so, delete the library and start again – you’ve screwed the library’s database. Or more precisely, FCPX is heavily database driven. If you’ve deleted something but the database doesn’t know it, weird things will happen.
Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland -
Noah Kadner
August 6, 2015 at 9:52 pmYeah unless you’re down to your last KB on a hard drive ‘deleting’ Projects doesn’t make much sense. Just start a new Library.
Noah
FCPWORKS – FCPX Workflow
Call Box Training -
Robin S. kurz
August 7, 2015 at 11:59 am[David Stembridge] “I shut down FCPx (10.2.1) and deleted the project folders from my movies/project-LIBRARY folder.”
I don’t even get why you would want to do that.
[David Stembridge] “the projects are still in my Library in FCPx… just no events and no option to delete.”
That makes no sense, unless you are in fact using an age old version of X… but even then… huh? Since how and where exactly can a project exist OUTSIDE of an event?? If you’re actually seeing projects directly within a library, then you’ve seriously messed things up and can only delete the library, yes.
– RK
____________________________________________________
Deutsch? Hier gibt es ein umfassendes FCP X Training für dich! -
Charlie Austin
August 9, 2015 at 3:24 amDid you update a pre 10.1 project/event pair to a Library? If so, what you’re seeing is expected as everything is in the new Library. is all the media there? If so, you can just delete the projects from the Library if you want to. Also, and sorry if I’m misunderstanding and this isn’t the case, but read up on how Libraries work in newer versions of X. 🙂
~ My FCPX Babbling blog ~
~”It is a poor craftsman who blames his tools.”~
~”The function you just attempted is not yet implemented”~ -
Bill Davis
August 9, 2015 at 6:18 pmJust in general, if you’re working in the Finder – you’re NOT working in the X database where it manages and stores everything it needs to operate the program.
So unless you’re a very experienced X operator, it’s best to try NEVER to mess with X stuff at the finder level.
It’s a database at its heart and as such MUST dependably know where it’s assets are located. Messing with the files via the finder puts you at risk.
FWIW.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
