Activity Forums Adobe Premiere Pro Removing a Piece of a Video CLip
  • Removing a Piece of a Video CLip
    Posted by Matthew Gonzalez on June 12, 2011 at 2:04 am
    I Need major help. Basically I want to recreate the album cover for the femme fatale remix single, but as a video with the heads moving basically. Now I have all the clips and they are all set up into different video layers, but I can’t figure out how to make the triangle shapes. How can I cut the video clip so that it looks like a triangle instead of a rectangle???
    Jon Barrie replied 15 years, 3 months ago 3 Members · 2 Replies
  • Todd Kopriva
    June 12, 2011 at 5:50 am
    You could draw a matte with the Four-Point Garbage Matte effect.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Jon Barrie
    June 14, 2011 at 12:52 pm
    This is some advanced stuff and worthy of a tutorial, but I will endeavor to help by text.
    There is always more than one way to skin a cat, so this is one way:
    – Make a Sequence just for the Triangluar video.
    – Place the video on track 1
    – Make a New Title and set the show background video button (top right) to on so you can see the video in the Title Design Area
    – Use the Pen tool to shape out the Triangle.
    – Make the fill white and uncheck any outter edges or shadows.
    – Make a Rectangle that fits the whole area and make it fill to Black.
    – Right click the Black Rectangle and “Arrange>send to back”
    – Now the white triangle should sit on top of the Black fill BG.
    – Add this Title to Track 2 directly on top of Track 1 clip length.
    In the Effects Panel type in Track Matte
    – Select the effect and drop it onto the video clip in track 1
    – Set the Effect Controls settings to see Track 2 as the Matte and you should now have a video only showing through the white triangle area.
    Make a new Sequence to composite the final edit with.
    – Add the build Sequence for the triangle to Track 3
    – Add the Left video to Track 1
    – Add the Right video to Track 2
    You might want to add crop effect to the clip on Track 2 to compose better. Track 1 clip will be under all the other clips and won’t need a crop, just move it into position.
    Edit away…!
    – JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
