Activity › Forums › Adobe Premiere Pro › Removing a Default Audio Transition
  • Removing a Default Audio Transition
    Posted by Patrick Kilchermann on November 11, 2013 at 3:06 pm
    I’ve got another one for you…
    At some point, “constant power” became my default audio transition. It’s probably the best ‘default’ audio transition, but I use the “apply default transition” shortcut of CTRL+SHIFT+D constantly, but I don’t want it effecting audio.
    The problem is, I don’t see a way to ONLY apply the default video transition, OR to remove the default audio one, and have nothing set as default for the audio. This is all I see:
    https://screencast.com/t/rupnj7pdzvJ
    If anyone can lend me a hand, I’d much appreciate it.
    Pat
    Marton Sender replied 6 years, 6 months ago 2 Members · 1 Reply
  • Marton Sender
    March 27, 2020 at 8:13 pm
    Maybe, like myself, someone else faces the same problem after 7 years… ☺
    It’s really annoying, I still did not find any solution for same problem in Adobe Premiere Pro CC 2018
    So I needed to figure it out myself:
    1: Exit the program
    2: Search for your settings file, my default location: C:\Users\username\Documents\Adobe\Premiere Pro\12.0\Profile-username\Adobe Premiere Pro Prefs
    3: Open this file with a text editor like Notepad++ my favourite
    4: Search for this: Constant Power
    5: Change “Constant Power” to “false”, so the line looks like this:
    false
    6: save the file, start the program and you’re done.
