Activity Forums Adobe After Effects Removing a dead pixel
  • Removing a dead pixel
    Posted by Derek Bowshier on June 9, 2011 at 2:07 am
    I recently found that my canon 5dmark II has a dead/hot pixel.
    I didn’t notice it until I began reviewing some footage, where it is quite noticeable on quite a bit of the footage when the iso was up.
    The footage is rather important and not something I can just re-shoot.
    What would be the most efficient method in AE to remove the pixal?
    I thought I read somewhere about a method that will automatically fill in the pixel based on the surrounding pixels?
    Thanks.
    Marc Nibor replied 15 years, 2 months ago 4 Members · 3 Replies
  • Todd Kopriva
    June 9, 2011 at 6:25 am
    A few ways spring to mind:
    You could use the CC Wire Removal effect.
    Or you could adapt this technique:
    https://blogs.adobe.com/sforde/2011/06/01/warp-stabilizre-redux/
    Or you could use the Clone Stamp tool.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Tudor “ted” jelescu
    June 9, 2011 at 6:29 am
    Or you can poke a hole through your layer using a mask, comp it on top of itself and shift 1-2 pixels (the direction depends on the shapes in the footage)
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Marc Nibor
    June 9, 2011 at 11:13 am
    >>Or you can poke a hole through your layer using a mask, comp it on >>top of itself and shift 1-2 pixels (the direction depends on the >>shapes in the footage)
    what a great idea!!
