Activity › Forums › Apple Final Cut Pro › Removing A Collection of Clips Without Deleting Other Things
  • Removing A Collection of Clips Without Deleting Other Things
    Posted by Kenny Evans on January 8, 2019 at 11:46 am
    One thing about the new FCPX that drives me nuts is that if you want to go in and delete a bunch of clips, it’s not that obvious or easy because of the way certain things link themselves to other things. In this example I have a load of small 1m segments that are topped and tailed and I want to remove all of that and put all the segments end to end.
    If I go in and select and delete the clips, it takes away certain audio as well, and even then I have to carefully look, often by enlarging the screen with the accessibility tool to see what is and ins’t connected. In the old days I would simply razorblade ALL in the timeline and it would get rid of everything I wanted without inadvertently removing bits I need.
    So what is the official way to do this kind of an edit in the new FCPX? I can’t use compound clips BTW as there are too may overlapping bits of media I need access to.
    Robin S. kurz replied 7 years, 8 months ago 2 Members · 1 Reply
  • Robin S. kurz
    January 11, 2019 at 5:21 pm
    [Kenny Evans] “So what is the official way to do this kind of an edit in the new FCPX?”
    Erm… new FCPX? It’s been that way since day one.
    Simply hold the “~” key (assuming you’re on a U.S. keyboard) when deleting, to temporarily override all connections. Done.
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
    Youtube | Facebook
