Activity Forums Adobe After Effects remove yellow line (roto)
  • remove yellow line (roto)
    Posted by Omnidecay on May 14, 2007 at 9:35 pm
    Does anyone know how to remove the yellow line connecting the dots whie rotoscoping? It covers up area and leaves a gap that is really annoying.
    Editor>God
    Omnidecay replied 19 years, 4 months ago 2 Members · 3 Replies
  • Kevin Camp
    May 14, 2007 at 9:50 pm
    if you’re talking about the mask lines… in the view menu, select view options. there you can uncheck show masks.
    however, i don’t think you will be able to select the mask points to edit. but you could select 2 views (from the bottom of the viewer) and turn off masks in the view options for one of the viewers, and work in the other viewer. a bit unusual, but i think it would work.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Omnidecay
    May 15, 2007 at 7:05 pm
    I dont want to turn the mask off completly/hide it. I was just wondering if there was a way to turn the lines off but keep the dots. For me, smaller roto jobs would go a lot faster if this was an option.
    Editor>God
  • Omnidecay
    May 16, 2007 at 1:12 am
    Well, I have never done it since I cant seem to make the yellow line transparent. I would assume looking at the difference in color from inside the mask vs outside would be a good indicator of where the line is. As for the difference in lines I guess you wouldnt really be able to. I would want the yellow dots still there just not the mask line. I think I’m coming to the conclusion that this is more of a wish list than a practicality. Thank you everyone.
    Editor>God
