Activity Forums Adobe After Effects Expressions Remove words from string
  • Remove words from string
    Posted by Jeremy Wick on March 7, 2022 at 8:42 pm
    Trying to come up with an expression that will remove whole words from a string. Removing characters is easy using substr, but not sure if there is a better method for removing whole words.
    str = "This is just an example.";
    remove = 2;
    output = "This is just"
    Filip Vandueren replied 4 years, 6 months ago 2 Members · 1 Reply
  • Filip Vandueren
    March 8, 2022 at 7:00 am
    Hi Jeremy.
    Here’s a quick try, but it replaces all whitespace characters with 1 space i the endresult. Also linebreaks will be gone, so it might be a too simple approach for you:
    remove = 2;
    arr = str.split(/\s+/gi); // yields an array of words
    output = arr.slice(0,-remove).join(" ");
