Activity › Forums › Apple Final Cut Pro Legacy › Remove the Lyrics
Remove the Lyrics
Posted by Kirk Johnson on June 30, 2007 at 10:24 pmIs there a way to remove lyrics from an existing AIF file?
Thaxter Clavemarlton replied 19 years, 2 months ago 7 Members · 7 Replies -
Bouncing Account needs new email address
July 1, 2007 at 3:15 amNo.
(That’s my answer and I’ll stick to it.)
Chris Babbitt
July 1, 2007 at 1:39 pmThere is a device that can fairly effectively remove the vocal from a recording as long as it is a stereo recording and the vocal is center-channel. This is a hardware device. I’m not sure if there is a software solution for this.
John Pale
July 1, 2007 at 3:22 pmNever used it myself, but you might want to give this a try.
https://primo-media.com/?page_Request=Products
July 1, 2007 at 5:07 pmDespite the other answers… mine remains, “no.”
Because:
A) the methods don’t work very well.
B) there are few “legal” reasons to remove vocals from commercial recordings.
Walter Biscardi
July 1, 2007 at 5:40 pm[Matte] “Despite the other answers… mine remains, “no.”
Because:
B) there are few “legal” reasons to remove vocals from commercial recordings.”
I’ll agree with that. If you really need something with no vocals, find the Karaoke version. That’s exactly what it’s for.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Herb Sevush
July 2, 2007 at 2:44 pmIf you have a stereo recording, and if ALL the vocals are center panned, and if all the rest of the music is placed off-center in the stereo field – then —
If you take one of the stereo channels and reverse the phase (many plug-ins can do this) then re-combine the 2 channels, theoretically the vocals will dissapear, as the audio that is identical on both channels (center panned) should cancel itself out if one channel is out of phase with the other.
Adobe’s audio program, Audition, has an effect that does just this but the resultant music sounds awful and generally a little of the singing still leaks thru.
Herb Sevush
Zebra Productions -
July 2, 2007 at 3:58 pm[Herb Sevush] “If you take one of the stereo channels and reverse the phase (many plug-ins can do this) then re-combine the 2 channels, theoretically the vocals will dissapear, as the audio that is identical on both channels (center panned) should cancel itself out if one channel is out of phase with the other.
Adobe’s audio program, Audition, has an effect that does just this but the resultant music sounds awful and generally a little of the singing still leaks thru.”
And since 99.99% of all the BASS is mixed dead-center, IT cancels as well.
You bet it sounds awful!
