Activity › Forums › Adobe After Effects › Remove Text from the Footage??
  • Chris Brett
    September 21, 2012 at 7:17 pm
    Vishesh – answer is probably to patch it from somewhere else in the shot but it depends – if you want to mail a still I’ll be able to tell you in more detail — chris
  • Tudor “ted” jelescu
    September 21, 2012 at 7:47 pm
    If the tilt is at a constant speed you may be able to offset the footage, key out the text and position the offset layer under in such a way that it matches the place where the text is. You will stil have to play around with cloning for the first part- making a clean plate (paint out the text) in PSD and moving that to match the camera move may help for that first part.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Chris Brett
    September 21, 2012 at 7:55 pm
    Vishesh
    …………..should be an easy one …
    1 ) take still into PS and carefully artwork out lettering
    2 ) take art-worked still into AE and apply 2 masks – one for each of piece of lettering – adjust feathering till perfect patch is made
    3 ) track shot if camera is not locked off apply motion track to cut-outs ( patches )
    4 ) If there is grain on your footage add a grain effect to your patches
    5 ) If hands move over type add as another layer on top and roto out / pull mask using footage as track matt.
    — and thats it …. should look perfect ———– chris —
  • Chris Wright
    September 22, 2012 at 12:11 am
    virtualdub and logoaway plugin is the easiest/fastest. as to the highest quality, I haven’t directly compared it to clone stamping.
