Activity › Forums › Adobe After Effects › Remove reflections when camera moves and person passes infront
  • Remove reflections when camera moves and person passes infront
    Posted by Bonn King on March 17, 2013 at 11:10 pm
    I have a shot where there are the crews reflections in a window and I need them removed. I’ve tried cloning and replacing the background with a Photoshopped image but the problem is that the camera tilts down and then the tracking gets messed up and also the actress passes in front of the reflections I want removed. Here is the clip it’s low res so you might not be able to see the ppl in the back https://youtu.be/gGdnVX52Nkk
    Angelo Lorenzo replied 13 years, 6 months ago 3 Members · 3 Replies
  • Darby Edelen
    March 17, 2013 at 11:44 pm
    [Bonn King] “I’ve tried cloning and replacing the background with a Photoshopped image but the problem is that the camera tilts down and then the tracking gets messed up and also the actress passes in front of the reflections I want removed.”
    Generating a clean plate of the background is a good first step.
    How are you currently tracking the clean plate into the shot?
    As for the actress passing in front of the reflections that will require rotoscoping of one variety or another.
    Darby Edelen
  • Bonn King
    March 18, 2013 at 1:58 am
    This is my first time really playing around with After Effects so I’ve been following video tutorials.
    I tried tracking this way but then when she comes in the frame or when the camera moves it shifts all over the place https://youtu.be/_fnJiMNyeiA Then i tried this one as well but the tutorial is simple compared to my footage so it didn’t work https://youtu.be/R4pxda2-vHE
    I could rotoscope but I don’t really know what to do after I’ve rotoscoped the girl https://youtu.be/u8cZPz4hVUM
  • Angelo Lorenzo
    March 18, 2013 at 2:27 am
    You could create a clean plate of the sightly above pure black that the window will be at, place it to cover the area partially (really only looks like you need to cover the crew member’s feet), and rotoscope the woman in front. The half of the frame with the hold man doesn’t need to be touched. It’d be a case for the rotobrush, there is good separation between the woman and background, could be painless.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
