Activity Forums Apple Final Cut Pro Legacy remove redundant frames in FCP 6?
  • remove redundant frames in FCP 6?
    Posted by Dit Ben on June 6, 2007 at 7:52 pm
    Hello everyone,
    is it possible to import a clip that is 720P50, with redundant frames, and export 720P25? It was simple in fcp 5.1, and now it doesnt seem to work – when I export using the presets (720P25) it still keeps the duplicate frames…
    Thanks a lot
    Dit Ben replied 19 years, 2 months ago 2 Members · 3 Replies
  • Gary Adcock
    June 6, 2007 at 9:36 pm
    [paris_ntz] “s it possible to import a clip that is 720P50, with redundant frames, and export 720P25?”
    did you try the FRC????
    it now works for 25/50p content.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
  • Dit Ben
    June 6, 2007 at 10:08 pm
    Doesnt seem to work for me: it tells me “the selected media file (clip0100.mov) cannot be processed by this tool – only dvcprohd 720P 59.94 and 50fps media files are supported).”
    Its as if fcp6 thought that the file is 25P (and thats what it tells me indeed), whereas fcp 5.1 would see that the exact same file is 50P.
  • Dit Ben
    June 6, 2007 at 10:13 pm
    By the way, I also checked with the AJA data rate calculator, and, indeed, my files are about twice the size they should be. None of them worked with the frame rate converter
