Activity Forums Adobe After Effects Expressions remove parent’s wiggle movement in child
  • remove parent’s wiggle movement in child
    Posted by Peter Zeet on November 28, 2019 at 5:54 pm
    hi!
    do you know if there is a way to counterpart a parent’s wiggle?
    I have a wiggle applied to a null (which is traveling in X ) , but I need its child null to get rid of his parent’s wiggle and have the paren’ts non wiggled movement
    I gave a try with some smooth, or negative values, but no luck at all, any suggestion will be more than welcome!
    thanks!
    Peter Zeet replied 6 years, 9 months ago 2 Members · 3 Replies
  • Dan Ebberts
    November 28, 2019 at 8:47 pm
    See if this works:
    seedRandom(parent.index-1);
    value – (wiggle(1,100)-value)
    Dan
  • Dan Ebberts
    November 28, 2019 at 8:48 pm
    Forgot to mention that you have to use the same wiggle formula that the parent uses.
    Dan
  • Peter Zeet
    November 29, 2019 at 12:23 pm
    works great! thanks!!
