Activity Forums Maxon Cinema 4D Remove or Delete Keyframes?
  • Remove or Delete Keyframes?
    Posted by James Hernandez on July 25, 2014 at 2:42 pm
    Sorry for such a simply question, but I’m having a hard time deleting key frames in my animation.
    Some people say:
    Open Object Manager
    “right click on whatever you have keyframes choose animation”
    I right click on my camera, or every object in my frame that is animated? Doesn’t everything in the view have keyframes? Anyways, I haven’t found anything I can right-click on that shows the Animation option.
    I tried placing the timeline cursor at a keyframe and hit Delete – nothing happened.
    Even when I go to Window > Object Manager, nothing opens. Object manager is the window already open by default.
    Confused, please help. Thanks. 🙂
    James Hernandez replied 12 years, 1 month ago 1 Member · 1 Reply
  • James Hernandez
    July 25, 2014 at 2:52 pm
    FASTEST WAY – I found a faster way to do this than opening up the Object Manager.
    Just keep your Timeline window open. You can quickly and easily delete keyframes from the Timeline as you work, or even if you have to go back and edit later.
    Thanks! 🙂
