Activity › Forums › Apple Final Cut Pro › Remove new effects/transitions
  • Brendan Gibbons
    June 30, 2011 at 12:39 pm
    If you mean remove a transition from final cut that you created in motion…so it doesn’t appear in fcp
    go to your home directory / movies / motion templates / transistions / and in there you will find the folder of the catergory if you gave it one and you should be able to find your transistion to delete…
    hope that helps,
    cheers
    Brendan
  • Jerry Hofmann
    June 30, 2011 at 1:08 pm
    Just select the transition and type on the delete key.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Geoff Dills
    June 30, 2011 at 2:33 pm
    Thanks…thought there would be a way to it inside X.
    Best,
    Geoff
  • Geoff Dills
    June 30, 2011 at 2:36 pm
    I’m guessing you’re talking about a transition in a timeline…I’m referring to the events palette which now I know I have to go outside X to manage.
    Best,
    Geoff
