Activity Forums Adobe After Effects Remove logo from clothes on video
  • Remove logo from clothes on video
    Posted by Mathieu Jacoulet on December 14, 2015 at 5:47 am
    Hello,
    I’ve been trying to remove that logo in After Effects. I really need an expert.
    here is the video : https://mega.nz/#!zBgHiBSZ!SOJCLO7-mkWWtBUHkKOwtTsQ2GgGQcIavMfwpKHcx-c
    What i’ve done so far :
    Tracking Logo – Nul Object
    1) Using Photoshop patch tool – Mask – Link to Nul
    2) Add Solid (same color as jacket) – Mask – Link to Nul
    3) Using Clone tool in AE – Link to Nul
    4) Using Paint – Link to Nul
    Everything is working but nothing it’s perfect. Who’s got a better idea ? 🙂
    Greuter Daysy replied 7 years, 10 months ago 4 Members · 6 Replies
  • Thomas Hannen
    December 14, 2015 at 9:30 am
    I’ve used a technique before where you use a 4 point gradient. You place nulls in a square around the logo, on the colour of the shirt at the corners but not touching the logo.
    You 2D motion track the logo, and use the track to move the four nulls.
    You use an expression to continuously get the RGB values at the four corners, color sampling at those points on every frame.
    Place a solid over the video and mask it to cover the logo.
    Track the position of the solid using the motion track you made earlier.
    Apply a four point gradient to the solid, where the four sets of RBG values are driven from the colour sampling expressions you made earlier.
    Feather the edges of the solid’s mask.
    I can’t remember the exact expression, or where I saw this technique, but I used it years ago and it worked well, because as the shirt moves it subtly changes colour.
    See Tristan’s example here :
    https://forums.creativecow.net/thread/2/970410
  • Martin Brennand
    December 14, 2015 at 12:03 pm
    You could probably do this quite quickly using mocha Pro’s remove module, using the illumination modelling options to add the right lighting back in.
    It just depends on how much of the original ming creases in the jacket you need to keep.
    Martin Brennand | Product Manager | mocha – Imagineer Systems
  • Mathieu Jacoulet
    December 15, 2015 at 6:22 pm
    Thank you both. It’s very helpful. I’ll try 🙂
  • Mathieu Jacoulet
    December 15, 2015 at 6:31 pm
    Thank you Martin, your technic seem to be very fast and i love mocha for tracking.
    Could you be more specific about illumination modelling options ?
    Do you have this tutorial on your vimeo page https://vimeo.com/mochapro ?
  • Martin Brennand
    December 16, 2015 at 9:12 am
    I’d recommend watching the quick 3-part series on the remove module here as a start: https://vimeo.com/108072190
  • Greuter Daysy
    November 16, 2018 at 3:08 pm
    A logo or a spot can be remove by special tools, like
    https://youtu.be/IGI57CIbISE
