Activity Forums Adobe Audition remove hum
  • remove hum
    Posted by Trey Selman on June 21, 2007 at 2:47 pm
    I have male voice speaking in a teaching session.
    I have a hum around 121Hz.
    Is it better to remove it with the Parametric Equalizer or to remove it with noise reduction.
    I can do it either way I am just not sure what is the better solution.
    If it is with the PEQ what should the Q value be (right now I have it set to 121.5 Hz -48db Q=2000) Is there a better way to deal with this hum?
    Thanks for your help.
    Trey Selman replied 19 years, 3 months ago 2 Members · 2 Replies
  • Willie Toth
    June 21, 2007 at 4:16 pm
    I would use the noise removal but make sure you capture JUST THE HUM first ……….. WILLIE
  • Trey Selman
    June 22, 2007 at 3:09 am
    Thank you very much for your advice.
    Trey Selman
