Activity Forums Adobe After Effects remove grain with adjustment layer
  • remove grain with adjustment layer
    Posted by Omid Abesta on March 6, 2011 at 9:58 pm
    hello
    I know english a little so answer simple
    when I apply every effects to Adjustment layer, lower layer (layers) affects from effect exist on Adjustment layer. but when apply remove grain to Adjustment layer , the layer that is below dosen’t change!
    why? what must I do?
    thank you
    Omid Abesta replied 15 years, 6 months ago 4 Members · 5 Replies
  • Joey Foreman
    March 6, 2011 at 10:37 pm
    Remove Grain defaults to a small region of interest preview. Change the Viewing Mode to Final Output.
    Joey Foreman
    Editor/Compositor/VFX Artist
  • Brian Charles
    March 7, 2011 at 6:59 pm
    The Remove Grain Effect does work on an adjustment layer.
    Check your preview and noise sample settings.
  • Omid Abesta
    March 8, 2011 at 12:35 am
    thank you
    but preview and noise sapmle is right.
    I apply the same effect on layer, is ok but when i cut it and paste on adjustment layer it dosent work!
    can you test it please?
  • Eric Epstein
    March 8, 2011 at 8:04 am
    Testing in CS5, Remove Grain works on an adjustment layer.
    I don’t know what would cause it to not work.
    Have you tested the adjustment layer with other effects, just to make sure it isn’t somehow disabled?
  • Omid Abesta
    March 8, 2011 at 7:38 pm
    Hello
    i used cs4 in vista. then i went to windows 7 and cs5. the problem was solved!
    thank you every one
