Activity Forums Adobe After Effects Remove Grain-starting settings for H.264 Compression artifact removal
  • Remove Grain-starting settings for H.264 Compression artifact removal
    Posted by Jim Bachalo on May 8, 2012 at 2:44 pm
    Hi
    Trying my best to use remove H.264 compression artifacts from some DSLR footage.
    The clip in question can be viewed here-
    https://vimeo.com/41773887
    pw-bells
    Can someone suggest usable starting settings for Remove Grain that might work?
    Or should I forget RG and use Neat Video instead?
    Local is the new global
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Dan Fredley replied 14 years, 3 months ago 2 Members · 1 Reply
  • Dan Fredley
    May 9, 2012 at 5:48 am
    You could get away with a complete sky replacement. Key out the blue using Keylight and replace it with another blue gradient or sky.
    Dan Fredley
