Activity Forums Adobe After Effects remove frames to make it look like an animation
  • remove frames to make it look like an animation
    Posted by Ewan Horlock on October 30, 2011 at 3:11 pm
    Hi there,
    I have some footage shot on green screen which I have added a rototoon effect to. This has made it look like a cartoon sketch.
    At the moment the footage is 25fps …and it looks way to fluid and smooth to be an animation.
    I was wandering could someone tell me how to remove frames. I want it still to run at 25 fps (so that its in sync with the music) but I would like to remove frames to make it more like stop motion animation.
    any help would be much appreciated 🙂
    Andreas Vlasov replied 14 years, 4 months ago 3 Members · 4 Replies
  • Todd Kopriva
    October 30, 2011 at 5:06 pm
    Precompose the layer, change the frame rate for the precomposition in the Composition Settings dialog box, and set Preserve Frame Rate When Nested Or In Render Queue for the precomposition on the Advanced tab. This method causes the precomposition to retain its own frame rate, and not inherit those settings from the containing composition.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Ewan Horlock
    November 2, 2011 at 12:09 pm
    thanks for your reply 🙂
    brilliant
    both effects work really well.
    Obviously with both its still running at 25fps its just doubling up on certain frames correct?
  • Todd Kopriva
    November 2, 2011 at 9:22 pm
    It works a little differently in each case. In the case of using the Posterize Time effect, all of the frames are rendered, and then only a fraction of those frames are used. In the case of using nested compositions and changing the frame rate, only the frames that are needed are rendered.
  • Andreas Vlasov
    May 18, 2012 at 2:18 pm
    Could you please describe more detail about how to find ‘Preserve Frame Rate’ I don’t see it on advanced tab?
    Check my great online service for animation making.
