Activity Forums Apple Final Cut Pro Legacy Remove effects globally
  • Remove effects globally
    Posted by David Eells on June 23, 2008 at 12:13 am
    I’ve inherited a large project with liberal use of BCC effects, which I don’t have. These have been causing FCP crashes during render and export to QT. Is there a way to globally remove effects? I want to leave any FCP native effects – just remove BCC in one easy step.
    Joe Haughey replied 18 years, 3 months ago 5 Members · 10 Replies
  • 10 Replies
  • Peter Wiggins
    June 23, 2008 at 12:35 am
    The easiest way I find to do this is to open the viewer at the effect/s you want to delete. Then toggle on ‘open’ in the canvas- this will keep that window view open for every clip
    Then advance to each clip using the keyboard, select the effect in the viewer and then delete. You can get quite quick at it 🙂
    Peter
  • David Eells
    June 23, 2008 at 12:39 am
    I guessI’ll have to – the show’s over an hour long!
    Thanks for the tip, Peter.
  • Hunter Stevens
    June 23, 2008 at 7:22 am
    I don’t have Boris, but can u just select all the shots, right click ‘remove attributes’, like with other filters?
    Never let the odds keep u from doing what u know in ur heart u were meant to do.
  • Peter Wiggins
    June 23, 2008 at 11:25 am
    Yes, but that will remove ALL the filters
    Peter
  • Jeremy Garchow
    June 23, 2008 at 7:53 pm
    This is a very new application that isn’t really even launched yet, but you can check them out:
    http://www.editmule.com
    Look for the EM Filter Remover.
    Jeremy
  • David Eells
    June 23, 2008 at 9:20 pm
    That’s just what I was looking for. Thanks, Jeremy.
    I couldn’t understand the testimonial on the Plug-in descritpion page, though 😉
  • Jeremy Garchow
    June 23, 2008 at 9:39 pm
    [David Eells] “I couldn’t understand the testimonial on the Plug-in descritpion page, though ;-)”
    Yeah, it’s a dead language 🙂
    Yes, the are brand new and haven’t officially launched.
    Good luck!
    Jeremy
  • Joe Haughey
    June 24, 2008 at 11:04 am
    Hi David, I wish we could release sooner, I totally empathize with your predicament.. its such a complete bore removing filters one by one…
    We’ll let the Cow now when we’ve launched..
    PS thanks for the plug Jeremy!! very kind..
    Joe Haughey
    https://www.editmule.com
    joe@editmule.com
  • David Eells
    June 25, 2008 at 12:48 am
    So Joe
    Do you need a beta tester? 😉
  • Joe Haughey
    June 25, 2008 at 7:51 am
    Thanks for volounteering David, but we’re soon ready to go with the first apps.. Send me an email though, we have more products in the pipeline
    joe@editmule.com
    Joe Haughey
