Activity Forums Maxon Cinema 4D Remove dynamics and keep positions
  • Remove dynamics and keep positions
    Posted by Seth Olson on October 4, 2012 at 7:11 pm
    So, between the cloner object and rigid body dynamics, I have placed hundreds of cubes where I am happy with them. Now, I want to remove the dynamics ( so they stop falling and bumping around) and then use the fracture object to make it mograph friendly.
    The problem is, when I delete the dynamic tags or make the cloner object edtable, it changes the position of everything. Suggestions?
    Thank you guys so much!
    Timothy Beck replied 9 years, 12 months ago 3 Members · 2 Replies
  • Brian Jones
    October 4, 2012 at 11:28 pm
    let your dynamics run to where your objects are where you want, then
    -Dynamics Body Tag/Dynamics/Set Initial State
    -Dynamics Body Tag/Cache/Bake Object
    this will take you back to frame 0 with the clones in their original position
    -Go forward 1 frame (should have clones in the right place)
    -make cloner Editable
  • Timothy Beck
    September 21, 2016 at 8:14 am
    I was also hoping to achieve the same results as the original poster, and your method worked perfectly. Thanks!
