Activity Forums VEGAS Pro remove ctrl-slide velocity change
  • remove ctrl-slide velocity change
    Posted by Rick Wise on October 3, 2008 at 7:01 pm
    I want to remove the velocity change I made on a shot by control-slide. I made that change many edits ago and can’t simply undo. Is there an easy way to restore the shot to its original state, other than deleting it and reinserting it from the media pool?
    Rick Wise replied 17 years, 11 months ago 2 Members · 4 Replies
  • Graham Bernard
    October 3, 2008 at 7:15 pm
    What is “control slide” for adjusting velocity?
    I know velocity Envelopes and Ctrl+Drag for accelerating? If it is the envelope then just delete the envelope. If it is the latter then Right click on the Video Event, select Properties and readjust Playback rate to 1.00.
    HTH
    Grazie
  • Rick Wise
    October 3, 2008 at 10:30 pm
    Thanks. I meant to write, control-drag.
    Rick Wise
    director of photography
    Oakland, CA
    http://www.RickWiseDP.com
    email: Rick@RickWiseDP.com
  • Graham Bernard
    October 4, 2008 at 5:58 am
    NP Rick! – Did that fix it for you?
    Grazie
  • Rick Wise
    October 4, 2008 at 6:18 pm
    Graham, indeed, that did the trick. Thanks!
    Rick Wise
    Oakland, CA
