Activity Forums Adobe After Effects Remove black background in Adobe video
  • Remove black background in Adobe video
    Posted by Gerald Hapeman on November 16, 2022 at 5:54 pm
    Have UnMult from Maxon-Red Giant and purchased a video from Adobe. Though Unmult removes the black background easily, the foreground object (animal) becomes almost transparent and you can see through it. How do I fix this? I think its removing black portions perhaps from the animal too? Green screen removals with Keylight works perfectly all the time, but black backgrounds (and I purchased several), are giving me trouble.
    Any suggestions?
    Gerald Hapeman replied 3 years, 10 months ago 3 Members · 5 Replies
  • Gerald Hapeman
    November 16, 2022 at 7:21 pm
    As a note, I used Unmult, which has the same effect as using key color and linear color key etc, etc… as they all have the same outcome – they remove the black (Alpha?) background but makes the animal stock transparent. When sliders are adjusted, even slightly, it brings back the black background. Almost impossible. Hopefully I haven’t wasted my money with these Adobe stock vids — MANY THANKS for any help!
  • Filip Vandueren
    November 17, 2022 at 9:31 am
    The Effect you’re looking for to do a Luma-based key is Keying > Extract.
    (Edit: Color Range in RGB-space with plenty of fuzziness, or Linear Color Key can also work, but Keyers based on Chroma won’t)
    Usually I follow it with Channel > “Remove Color Matting” to get rid of some black fringes.
    You’ll have to manually mask back in some black areas (like the pupils or shadowy mouth for example) that you don’t want to be transparant.
  • Walter Soyka
    November 17, 2022 at 4:27 pm
  • Gerald Hapeman
    November 18, 2022 at 12:34 am
    Thank you – Ill give it a whirl!!
  • Gerald Hapeman
    November 18, 2022 at 12:35 am
    Thank you – Rotoscoping may solve the issues, but this animal is pretty hairy… so I wonder. The link is helpful!
