Activity Forums Apple Final Cut Pro Legacy Remove Audio Noise? weird buzzing…..
  • Remove Audio Noise? weird buzzing…..
    Posted by Randy Whitlock on October 23, 2012 at 5:11 pm
    I am trying to remove some audio noise from a few clips. The odd thing is, I don’t notice it when playing the clips normally, but can hear this odd popping/buzzing when I play fast-forward. I tried reworking the clips at a different audio rate, but same result. Thoughts?
    I am using FCP 7.
    Michael Gissing replied 13 years, 10 months ago 4 Members · 3 Replies
  • Ernie Santella
    October 23, 2012 at 5:28 pm
    Try taking the clips into Apple Soundtrack Pro. (You already have it. It comes with the Final Cut suite) It does a good job of reducing noise.
    Ernie Santella
    Santella Productions Inc.
    http://www.santellaproductions.com
  • Mark Suszko
    October 23, 2012 at 6:17 pm
    you can also try Levelator for free.
    if you her it when fast-shuttling, it’s probably low-frequency hum or motor noise from a camera or something in the room. You can probably kill it with a notch filter.
  • Michael Gissing
    October 23, 2012 at 9:29 pm
    Try a high pass filter set to 70hz. Most likely low frequency noise like rumble which you might not be picking up on your speakers.
    Levelator is not noise reduction but a form of normalising with some dynamics compression.
