Activity Forums VEGAS Pro Remove Audio from Quicktime Files / Media Library
  • Remove Audio from Quicktime Files / Media Library
    Posted by Scott Wright on June 26, 2010 at 10:40 am
    Hi There!
    I work with a lot of quicktime files that have both a video and audio layer to them. I never use the audio that is supplied, so I either have to delete the audio track that is added to the timeline, or right click from the media library and select add video only.
    Either way results in quite a delay to my workflow. Is it possible to either batch remove the audio stream from a set of quicktime files, or perhaps within vegas tell the software to only work with the video streams? I would prefer not to re-encode any of the actual video.
    Appreciate anyones help in advance here, and also recognise its a bit of a strange question!
    John Rofrano replied 16 years, 2 months ago 2 Members · 1 Reply
  • John Rofrano
    June 26, 2010 at 11:51 am
    What you are doing now, i.e., right-click drag and select Video Only is the correct way to do it. That is the workflow within Vegas to just add video. I don’t know of any batch processor that will remove the audio from Quicktime files and not re-encode the video.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
