Remove Audio Clicking/Skipping in Vegas?
Posted by Morgan Lewis on November 11, 2014 at 6:43 amSo something weird happened in some audio I recorded, I’m not very savvy when it comes to fixing audio problems. I asked over at the audacity forums and although the tool they directed to me works, as someone gave me an example. (It’s called the De-Clicker plugin), for some reason it makes audacity crash when I use it.
Does Vegas have any audio tools that could be used to remove.. or at least dull the weird clicking noise in my file? Below is a small example from the session.
Morgan Lewis replied 11 years, 10 months ago 5 Members · 7 Replies -
Graham Bernard
November 11, 2014 at 11:52 amMorgan? Please ensure your Project Audio Settings match your Audio Media. Then APPLY and Save>Close>Reopen Vegas. See if that improves matters.
G
Cameras: Canon XF300 + PowerShot SX50HS Bridge -
Morgan Lewis
November 11, 2014 at 12:01 pmThe settings match, there was a problem when I recorded the audio and it make this skipping noise appear in a few places. Does Vegas have any tools that can help iron them out?
Bob Peterson
November 11, 2014 at 5:47 pmVegas Pro has an audio fx called Click & Crackle remover. That may remove the clicks you are hearing.
Morgan Lewis
November 12, 2014 at 1:05 amI don’t seem to have that in my Audio FX, I’m using Vegas Pro 10… I don’t suppose it’s possible to download that plugin for my version?
Mike Kujbida
November 12, 2014 at 1:57 amI’m using Pro 10 and I do have it but I also have Sound Forge Pro 10 installed and I’m pretty sure that’s where it comes from.
Russ Froze
November 12, 2014 at 7:40 pmIn short, the answer is yes and no. Vegas does have a very robust audio support, after all Vegas Video was born from Sonic Foundry Acid Which is an audio application. Marketing is the issue, Video will only have the most basic of plug ins to do the basic job of cleaning audio. There are hundreds of Pug ins on the market but I doubt you will find one that will remove the offending sounds automatically.
I brought your sample into SpectraLayers just to have a look. Yes the clicks can be removed but from the length of the sample it’s difficult to tell what is not suppose to be in the file. Some sound could be music in the background but to my ears they sound more like a cpu switching issue as if the recorder was taxed during the recording for some reason. Again I have no idea as to the recording system but it sounds taxed or overloaded.
I would much like to see the entire file as to ascertain the degree of work needed to clean it up and determine if it’s worth the effort for it will undoubtedly take days if not weeks.
Just to be clear, I’m not volunteering for the task but I will help you to make a decision as to weather to continue or drop the project.
Russ Froze -
Morgan Lewis
November 13, 2014 at 4:59 amThe project is several gigs large, it would probably be easier to run the buggy audacity plugin 10 minutes at a time than to upload it to show.
I have been told the clicks are because the audio program was struggling to write, this is because I accidently had video recording settings far too high.
