Activity Forums Adobe After Effects Remove all shape layers in selected composition
  • Remove all shape layers in selected composition
    Posted by Arun Chaudhary on July 21, 2017 at 2:31 pm
    After effects, script remove all shape layers in selected composition
    any idea? how can do this
    Thanks.
    Arun Chaudhary replied 9 years ago 3 Members · 5 Replies
  • Jim Scott
    July 21, 2017 at 6:06 pm
    I don’t know how to create a script, if that’s what you’re asking, but if you just want to remove all shape layers: Enter “shape” in the search window above the layers in the Timeline panel. Drag to select them all (don’t use “select all”)… delete. Clear the search window by clicking the X and the remaining layers will be displayed.
  • Arun Chaudhary
    July 22, 2017 at 4:55 am
    Thank you, Jim Scott, for your reply but this is not work in my case i have 500 hundred + comp. so I don,t want open all 1 by1 I want select all comp run script then removed all shapes layer in comp.
  • Walter Soyka
    July 23, 2017 at 11:50 am
    Here’s a quick script that will remove all shape layers in the selected comps in a project (or in the active comp if no selection is made).
    Back up your project file first and use this at your own risk!
    function deleteAllShapeLayersInComp(comp) {
    // delete all shape layers in the specifed comp
    // step through the comp, removing any shape layers as we go
    // work backwards from the last layer, because removing later layers won't affect the indices of earlier ones
    for(var i = comp.numLayers; i >= 1; i--) {
    if (comp.layers[i] instanceof ShapeLayer) comp.layers[i].remove();
    function processProjectSelectionComps(func) {
    // go through all selected items in a project. if they're comps, perform the specifed function on them
    if (app.project.selection.length > 0) {
    for (var i = 0; i < app.project.selection.length; i++) {
    if (app.project.selection[i] instanceof CompItem) {
    func(app.project.selection[i]);
    app.beginUndoGroup("Delete All Shape Layers");
    processProjectSelectionComps(deleteAllShapeLayersInComp);
    } else if (app.project.activeItem instanceof CompItem) {
    deleteAllShapeLayersInComp(app.project.activeItem);
    app.endUndoGroup();
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Arun Chaudhary
    July 26, 2017 at 6:10 am
    Hi, Walter Soyka
    I want to say you are legends you make my day you script work fine as I want
    Thank you so much
  • Arun Chaudhary
    September 14, 2017 at 1:26 pm
    again I need your help I find a post for Remove all files in a shape layer, John Colombo script works fine for active comp. but I want this script works for selected comp. in a project
    and add a stroke in all shape layer stroke width can be set. if it is possible
    https://forums.creativecow.net/thread/227/30520
    I am very grateful to you
    Arun
