Activity › Forums › Avid Media Composer › Remove all color correction from a sequence
Posted by Frederic Lumiere on August 27, 2014 at 10:12 pmIs there a quick way to remove all color correction from a sequence without affecting other FX/Transitions?
John Pale replied 12 years ago 3 Members · 6 Replies -
Frederic Lumiere
August 27, 2014 at 11:16 pmANSWER: In Effect mode, lasso clips w/ corrections, hit delete. But this will also delete other fx. Pls test Thanks @filmgeek Jeff Greenberg!
John Pale
August 28, 2014 at 12:52 amWhen in color correction mode, the remove effect button will only remove color corrections. You can select all and delete them
Frederic Lumiere
August 28, 2014 at 2:12 amWhen I’m in color correction mode somehow I’m not able to select all clips. When I remove effect, it deletes the last effect (even if it’s not color correction)
Job Ter burg
August 28, 2014 at 9:31 amIn the CC tool, right click and select “Remove Corrections”.
Job Ter burg
August 28, 2014 at 9:34 amCome and think of it, that functionality may be part of the Symphony option.
John Pale
August 29, 2014 at 3:17 amApologies. Don’t know what I was thinking. You are right. It does not work.
