Activity › Forums › Avid Media Composer › Remove Advanced Pulldown from P2 Footage
  • Remove Advanced Pulldown from P2 Footage
    Posted by Matthew Sonnenfeld on May 21, 2013 at 5:24 pm
    Hello,
    Is there any way to remove advanced pulldown from 1080/24pA material from an HPX170 within Media Composer?
    Blackmagic Cinema Camera, RED Scarlet-X, Panasonic HPX170, Canon 7D
    2011 Macbook Pro 17″, 2.3 Ghz Quad Core, 16GB RAM
    AJA IoXT
    Adobe Production Premium CS6, Avid Symphony 6, Final Cut Pro Studio 3
    The College of William and Mary
    Matthew Sonnenfeld replied 13 years, 4 months ago 3 Members · 5 Replies
  • Michael Phillips
    May 21, 2013 at 6:02 pm
    In file based world, you would be better served shooting native 23.976pN than trying to remove it later in post. You also get a 20% increase in storage capture with those P2 cards.
    But that aside, open your clips in a 1080i/59.94. Then open those bins in your 23.976. A mix and match motion adapter will automatically be applied leaving you with 23.976 native for editing.
    Michael
  • Matthew Sonnenfeld
    May 21, 2013 at 6:03 pm
    Thanks Michael for the motion adapter advice.
    Unfortunately 24pN options are not available in 1080 using DVCPRO HD. Only pA.
    AJA IoXT
  • Michael Phillips
    May 21, 2013 at 6:10 pm
    Ah… too bad. It has been a while since I have touched any of these formats. The latter will work for you though.
    Michael
  • Shane Ross
    The HPX 170 and HVX 200 and 200a make better images at 720p than 1080, in my experience. I ONLY shoot 720p 24PN with those cameras. Then cross convert to 1080 for delivery. Always looked great.
    Shane
    Little Frog Post
    May 21, 2013 at 6:24 pm
    Hi Shane,
    That’s typically my workflow for the 170 as well but unfortunately I had to be mixing with previous footage from a Blackmagic Cinema Camera, a 7D, and a GoPro Hero2 so I was trying to match as much as I could to keep everything playing together nicely.
    I know, the amount of of mess here is astonishing!
    AJA IoXT
