Activity › Forums › Adobe After Effects › Remove a static background using the differences in the shot
  • Remove a static background using the differences in the shot
    Posted by Florian Schneider on November 9, 2018 at 10:06 pm
    Hello creative people,
    I’ve been thinking of a way to remove a moving subject from his background without rotoscoping.
    Knowing that in my case, there isn’t any greenscreen.
    More important though, knowing that i’m talking about shots with a static camera.
    Is there a way in Adobe After Effects to tell the software :
    – This is the shot of the background with the subject
    – This is the same shot with the background only. Without the subject
    – Pease (yeah I know, I’m polite with my softwares), AE, could you put out the subject from the first shot using the differences between the two shots ?
    It seems so easy said this way. So easy that I would be surprise that such a feature doesn’t exist, right ?
    PS: When I was a kid, I remember using my webcam with a software that could remove the background from me using this technique
    The method was simple : I had to push a button, get away from my background for 5 seconds and then the background was gone once I was back in front of my webcam ! As simply as this.
    Florian Schneider replied 7 years, 8 months ago 1 Member · 1 Reply
  • Florian Schneider
    January 26, 2019 at 4:23 pm
    It is “Difference Matte” indeed ! Thank you !
    Unfortunately it didn’t work well with the footage I had.
    Many issues. For exemple : having a subject with a white T-shirt in front of a gray wall. With so, the effects is not doing great.
    But I must say that it might come from my camera. I’ve shot with my Sony HXR-MC2000e which compress the rushes in a 1440p resolution. There is a noise on the image due to (I think) the low quality of the camera lens (and of course it’s a fix camera lens !).
    Got this camera since nearly 10 years now on. It’s maybe time to switch aha !
    Thank you for the quick answer. (and sorry for the delay of my re-answer)
