Activity Forums Adobe After Effects remove a color cleanly and replace with another
  • remove a color cleanly and replace with another
    Posted by Lori Newman on May 19, 2012 at 6:00 pm
    I have a client job and need to easily and cleanly remove a color from and image
    and replace it with another. the colors aren’t in solid blocks. I tried replace color
    with no luck. Does anyone have a suggestion of a plugin or other way to do this?
    thanks!!!
    Tudor “ted” jelescu replied 14 years, 4 months ago 3 Members · 2 Replies
  • Dale Kutzera
    May 19, 2012 at 6:08 pm
    I’ve used the change-color brush in Photoshop with good results.
  • Tudor “ted” jelescu
    May 19, 2012 at 7:04 pm
    One way would be to use a Color Range Key to key out the color from the image and then use the same footage under the layer with the key to color correct for those areas to the desired color.
    Tudor “Ted” Jelescu
    Senior VFX Artist
