Activity Forums Avid Media Composer Removal of image using avid effects editor
  • Removal of image using avid effects editor
    Posted by Pandamela on June 27, 2006 at 3:11 pm
    I have a shot with a man looking at himself in a mirror, and I would like to remove the image of the man but keep the mirror and the background to use with a greenscreen shot. Does anyone know of a way that I can do this in Avid? I’ve tried using the scratch removal effect with the avid effects manual but it’s not very clear and I am getting nowhere fast.
    Any ideas would be greatly appreciated.
    Thanks in advance
    Oliver Peters replied 20 years, 2 months ago 3 Members · 3 Replies
  • Oliver Peters
    June 27, 2006 at 3:53 pm
    Did you shoot a clean plate of the mirror and background only? That’s pretty imperative to making this work. Also, does your shot have a camera move or is it locked off?
    Sincerely,
    Oliver
    Oliver Peters
    Post-Production & Interactive Media
    Orlando, FL
    http://www.oliverpeters.com
  • Jason
    June 27, 2006 at 4:13 pm
    you would use the animatte plugin to create an animated mask as you would in after effects. its basically rotoscoping.
    j
  • Oliver Peters
    June 27, 2006 at 4:25 pm
    Animatte is available IF he’s on Media Composer or Symphony and not Xpress DV or Pro. You still need a clean background to replace the person’s image, though. The only other alternative is to make sure the greenscreen person is big enough to cover-up the person in the image below.
    Sincerely,
    Oliver
    Oliver Peters
    Orlando, FL
