Activity › Forums › Apple Final Cut Pro Legacy › REMOTE DISC/FCP7 Installer Issue
  • REMOTE DISC/FCP7 Installer Issue
    Posted by Aaron Gentry on June 30, 2015 at 2:22 pm
    Hello all, I don’t post here often, so if I have posted in the wrong spot, please forgive.
    I recently upgraded from an older Mac to the New Mac Pro, which does not have a CD/DVD drive. I am trying to install Final Cut Studio but have gotten stuck. While using Remote Disc from my older computer, the Final Cut Studio installer asks for the next disc in the installation, but does not recognize when the disc has been inserted into the remotely used computer. Does this make sense? Has anyone experienced this? Anyone know a way around this?
    If it matters I am using Yosemite 10.10.3
    Aaron Gentry replied 11 years, 2 months ago 3 Members · 4 Replies
  • Warren Eig
    June 30, 2015 at 3:20 pm
    Easiest solution is to make disc images of all the discs. Mount them all on the desktop, start the installer and go grab a cup of coffee. It will install what you select without asking for the next disc because you’ve mounted all the images 😉
    Warren Eig
    O 310-470-0905
    email: warren@babyboompictures.com
    website: https://www.BabyBoomPictures.com
    REEL: https://www.babyboompictures.com/BabyBoomPictures/Reels.html
    For Camera Accessories – Monitors and Batteries
    website: https://www.EigRig.com
  • Shane Ross
    June 30, 2015 at 6:32 pm
    Either that or buy an external Superdrive.
    Shane
    Little Frog Post
  • Aaron Gentry
    July 1, 2015 at 3:11 pm
    “Easiest solution is to make disc images of all the discs.”
    I thought about this. I eventually found a friend with an external DVD drive, though. Thanks for your reply!
  • Aaron Gentry
    July 21, 2015 at 7:18 pm
    While I found an external drive, I was intrigued by your advice. Did not know a sequence of installs would work on their own given the next image was mounted. thanks for that info! seems pretty obvious but i never thought of it. Thanks, again. I’m sure it will be helpful in the future
