Activity Forums Adobe After Effects Expressions remapping speed of a property with audio
  • remapping speed of a property with audio
    Posted by Micheel Leavitt on August 19, 2009 at 6:16 am
    What I am trying to do is have a property be going at a certain speed, but speed up as an audio amplitude value increases, then slow back down as it decreases, but I want it to hold the value of the frame previous and apply the speed change to that value, because the code I am using below will go back to a lower value.
    mus = thisComp.layer(“Audio Amplitude”).effect(“Both Channels”)(“Slider”);
    x = ease(mus,1,9.5,0,1);
    time*(1.1+x)
    I am pretty sure this can only be done with a while loop, but I am not really sure where to begin to write it, only that it needs to repeat while “mus” is between 1 and 9.5, and I still want it to move even if it is under 1. (At a rate of 1.1)
    Any help with this would be most appreciated. Thanks!
    Micheel Leavitt replied 17 years ago 1 Member · 0 Replies
  • 0 Replies
